VDSL2 stats are not shown in Web UI and SQL Integrity constraint violation errors in logs
Hi all,
I have an issue when running discovery against a Draytek 167. The VDSL2 statistics aren’t shown in the web UI and an SQL error is present in the logs:
Error discovering xdsl module for 192.168.2.1.[0m PDOException: SQLSTATE[23000]: Integrity constraint violation: 1062 Duplicate entry '0' for key 'ports_adsl_port_id_unique' in /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Connection.php:580
My install appears to be correct with no issues:
LibreNMS  | 23.11.0-14-g13c934ab0 (2023-12-01T23:34:21+00:00)
DB Schema | 2023_11_21_172239_increase_vminfo.vmwvmguestos_column_length (274)
PHP       | 8.1.26
Python    | 3.9.2
Database  | MariaDB 10.11.5-MariaDB-log
SNMP      | 5.9
[OK]    Composer Version: 2.6.5
[OK]    MySQl and PHP time match
[OK]    Redis is unavailable
Please find as well the full output of the Discovery processes in the PasteBin: Untitled - LibreNMS
Any help with this issue would be greatly appreciated, thank you in advance.
Hi @Sweeny42
Do you have this issue with all your Draytek 167 devices, or only one ? If yes, it might be something with this one (was it added a long time ago, a migration might have done something weird with one DB column) ?
Hi @PipoCanaja,
I sadly only have a single Draytek 167 to test with. I have tried re-adding the device etc but to no avail. same issue is produced. This is a rather old install, I believe it’s been running for over 3 years so it’s possible a migration may have gone a tad sideways. Is there any method to do a healthcheck on the DB?
Many thanks.
In further answer to your question, no this device was only added in the last week.
Nope, if the device was added last week, then it did not have time to suffer from any migration issue.
Could you collect the SNMP data with this command:
snmpwalk -v2c -OUneb -Cc -c <community> <ipOfDevice> . > capture.ouneb.txt and send me the result here ? That should allow me to reproduce the issue, and hopefully fix it.
Hi @PipoCanaja
Of course, please find the output below in the following link: https://pastebin.com/raw/J67y1T8M
Do let me know if I can be of any further help and thanks again for looking into this issue for me.
issue reproduced. Will try to fix it
Hi @Sweeny42
Found the issue, but this is a bug in the device itself. The device provides “0” as the index, instead of the index of interface that is the DSL port. So LibreNMS cannot find the interface to attach to and does indeed crash.
I’ll remove the crash by checking if mapping is wrong, but I cannot fix the device to provide the real index. So your best hope is to upgrade the device to the latest version and hope they did fix it. Or change device of course :slight_smile:
librenms@librenms:~$ '/usr/bin/snmpbulkwalk' '-M' '/opt/librenms/mibs' '-m' 'SNMPv2-TC:SNMPv2-MIB:IF-MIB:IP-MIB:TCP-MIB:UDP-MIB:NET-SNMP-VACM-MIB' '-v2c' '-c' 'draytek_full'  'udp:127.1.6.1:1161' 'ADSL-LINE-MIB::adslMibObjects'
ADSL-LINE-MIB::adslLineCoding.0 = INTEGER: dmt(2)
ADSL-LINE-MIB::adslLineType.0 = INTEGER: fastOrInterleaved(4)
ADSL-LINE-MIB::adslLineSpecific.0 = OID: SNMPv2-SMI::zeroDotZero
ADSL-LINE-MIB::adslLineConfProfile.0 = STRING: VDSL2
<snip>
ADSL-LINE-MIB::adslAturChanCurrTxRate.0 = Gauge32: 10233856 bps
ADSL-LINE-MIB::adslAturChanPrevTxRate.0 = Gauge32: 0 bps
ADSL-LINE-MIB::adslAturChanCrcBlockLength.0 = Gauge32: 2
Fix is here :
It removes the crash only in your case.
Hi @PipoCanaja
Thanks again for the validation check. I will contact Draytek with a bug report and hope to hear back soon. I have merged your pull request and can confirm the check works as expected for me. Once again thanks!
