Virtual Machine Images (OVA) removal (Update: cancelled)
The Virtual Machine OVA files have been unmaintained for several years.
At least some of them won’t result in a working LibreNMS install at this time.
It is a major source of confusion that the OVA is not compatible with VMWare (The disk images are)
I believe the OVAs are doing more harm than good at this point.
I will be deleting them at the end of this month, on 5/1/2023.
Alternatives:
Docker Images
Install on a linux VM
@laf has updated the OVAs and attempted to add a VMware compatible image.
