Vlan page not working
Hi
When I click on vlan tab of my core switch the page shows nothing, below is the screenshot of the same. Anyone know the issue and can help.
./validate.php
LibreNMS 22.11.0-34-gae22662c8 (2022-12-19T11:54:34+03:00)
DB Schema 2022_09_03_091314_update_ports_adsl_table_with_defaults (248)
PHP 8.1.2-1ubuntu2.8
Python 3.10.6
Database MariaDB 10.6.11-MariaDB-0ubuntu0.22.04.1
SNMP 5.9.1
[OK] Composer Version: 2.4.4
[OK]
[OK] MySQl and PHP time match
Regards
Most likely because you need to increase the php cache, if you’re in docker check the .librenms file and otherwise just change php.conf
Hi @ElemondCraw
Thank you for the reply, may I know where can I find the setting for php cache and I am not using docker. And little brief about the setting.
Thank you
It’s in your php.ini file
You have to change
memory_limit = 256M
And try increase it so it work
memory_limit = 2G for example for 2 gig
Hi @ElemondCraw
Thank you for the solution.
Regards
