VLANs not discovered on MikroTik CRS354-48P-4S+2Q+ and CRS328-24P-4S+, but working on CRS518-16XS-2XQ
Hello LibreNMS Community,
I’m having issues with VLAN discovery on some of my MikroTik RouterOS switches in LibreNMS. Specifically, VLANs are correctly detected and displayed for a CRS518-16XS-2XQ (RouterOS 7.16.1, License Level 6), but not for a CRS354-48P-4S+2Q+ (RouterOS 7.16.1, License Level 5) or a CRS328-24P-4S+ (RouterOS 7.19.4, License Level 5). I’ve followed the same configuration steps for all devices as per the official LibreNMS RouterOS documentation https://docs.librenms.org/Support/Device-Notes/Routeros/.
Problem Description:
  • On the CRS518, VLANs are correctly discovered and shown in the device’s VLANs tab and under port details.
  • On the CRS354 and CRS328, VLANs are not displayed in the VLANs tab, and port details either show no VLANs or incorrect assignments (e.g., all ports as “untagged” or empty VLAN lists).
  • Force rediscovery (-f) and polling (-p) via ./discovery.php and ./poller.php did not resolve the issue.
My Setup:
  • Devices and Firmware:
    • CRS518-16XS-2XQ: RouterOS 7.16.1 (Level 6) – VLAN discovery works
    • CRS354-48P-4S+2Q+: RouterOS 7.16.1 (Level 5) – VLAN discovery fails
    • CRS328-24P-4S+: RouterOS 7.19.4 (Level 5) – VLAN discovery fails
/opt/librenms $ ./validate.php
LibreNMS 25.8.0 (2025-08-20T19:11:01+02:00)
DB Schema 2025_07_29_025425_hr_device_table_add_type_default (353)
PHP 8.3.24
Python 3.12.11
Database MariaDB 10.11.13-MariaDB-ubu2204
RRDTool 1.9.0
SNMP 5.9.4
[OK] Redis is functional
