When I try to access Virtual Machines from the device drop down, the page loads with no results found.
I have 2 VMware hosts which are working fine. This page was previously populated. In my NGINX logs, I am getting a 500 error:
XXXX - - [18/Nov/2020:08:58:01 -0500] “POST /ajax/set_resolution HTTP/2.0” 200 28 “://librenms.myhost./vminfo” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/86.0.4240.198 Safari/537.36” librenms.myhost.443 “HTTP/2.0” “-”
XXXX - - [18/Nov/2020:08:58:01 -0500] “POST /ajax/table/vminfo HTTP/2.0” 500 69 “://librenms.myhost./vminfo” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/86.0.4240.198 Safari/537.36” librenms.myhost.443 “HTTP/2.0” “-”
XXXX - - [18/Nov/2020:08:58:01 -0500] “GET /images/manifest.json HTTP/2.0” 304 0 “://librenms.myhost./vminfo” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/86.0.4240.198 Safari/537.36” librenms.myhost.443 “HTTP/2.0” “-”
Validate:
[email protected]:~/logs$ ./validate.php
-bash: ./validate.php: No such file or directory
[email protected]:~/logs$ cd …
[email protected]:~$ ./validate.php
Component | Version |
LibreNMS | 1.69-34-g3daacc5e1 |
DB Schema | 2020_11_02_164331_add_powerstate_enum_to_vminfo (190) |
PHP | 7.4.3 |
Python | 3.8.5 |
MySQL | 10.3.25-MariaDB-0ubuntu0.20.04.1 |
RRDTool | 1.7.2 |
SNMP | NET-SNMP 5.8 |
OpenSSL |
[OK] Composer Version: 2.0.7
librenms.log
[2020-11-18 09:11:18] production.ERROR: Return value of App\Models\Vminfo::getStateLabelAttribute() must be of the type string, array returned {“userId”:1,“exception”:"[object] (TypeError(code: 0): Return value of App\Models\Vminfo::getStateLabelAttribute() must be of the type string, array returned at /opt/librenms/app/Models/Vminfo.php:22)
[stacktrace]
#0 /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Eloquent/Concerns/HasAttributes.php(481): App\Models\Vminfo->getStateLabelAttribute()
#1 /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Eloquent/Concerns/HasAttributes.php(1494): Illuminate\Database\Eloquent\Model->mutateAttribute()
#2 /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Eloquent/Concerns/HasAttributes.php(394): Illuminate\Database\Eloquent\Model->transformModelValue()
#3 /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Eloquent/Concerns/HasAttributes.php(373): Illuminate\Database\Eloquent\Model->getAttributeValue()
#4 /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Eloquent/Model.php(1625): Illuminate\Database\Eloquent\Model->getAttribute()
#5 /opt/librenms/app/Http/Controllers/Table/VminfoController.php(63): Illuminate\Database\Eloquent\Model->__get()
#6 [internal function]: App\Http\Controllers\Table\VminfoController->formatItem()
#7 /opt/librenms/vendor/laravel/framework/src/Illuminate/Collections/Collection.php(630): array_map()
#8 /opt/librenms/app/Http/Controllers/Table/TableController.php(87): Illuminate\Support\Collection->map()
#9 /opt/librenms/app/Http/Controllers/Table/TableController.php(75): App\Http\Controllers\Table\TableController->formatResponse()
#10 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/Controller.php(54): App\Http\Controllers\Table\TableController->__invoke()
#11 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/ControllerDispatcher.php(45): Illuminate\Routing\Controller->callAction()
#12 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/Route.php(255): Illuminate\Routing\ControllerDispatcher->dispatch()
#13 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/Route.php(197): Illuminate\Routing\Route->runController()
#14 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/Router.php(691): Illuminate\Routing\Route->run()
#15 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(128): Illuminate\Routing\Router->Illuminate\Routing\{closure}()
#16 /opt/librenms/app/Http/Middleware/LoadUserPreferences.php(30): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#17 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): App\Http\Middleware\LoadUserPreferences->handle()
#18 /opt/librenms/app/Http/Middleware/VerifyTwoFactor.php(39): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#19 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): App\Http\Middleware\VerifyTwoFactor->handle()
#20 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/Middleware/SubstituteBindings.php(41): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#21 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\Routing\Middleware\SubstituteBindings->handle()
#22 /opt/librenms/vendor/laravel/framework/src/Illuminate/Auth/Middleware/Authenticate.php(44): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#23 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\Auth\Middleware\Authenticate->handle()
#24 /opt/librenms/app/Http/Middleware/LegacyExternalAuth.php(42): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#25 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): App\Http\Middleware\LegacyExternalAuth->handle()
#26 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/VerifyCsrfToken.php(77): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#27 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle()
#28 /opt/librenms/vendor/laravel/framework/src/Illuminate/View/Middleware/ShareErrorsFromSession.php(49): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#29 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\View\Middleware\ShareErrorsFromSession->handle()
#30 /opt/librenms/vendor/laravel/framework/src/Illuminate/Session/Middleware/StartSession.php(121): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#31 /opt/librenms/vendor/laravel/framework/src/Illuminate/Session/Middleware/StartSession.php(63): Illuminate\Session\Middleware\StartSession->handleStatefulRequest()
#32 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\Session\Middleware\StartSession->handle()
#33 /opt/librenms/vendor/laravel/framework/src/Illuminate/Cookie/Middleware/AddQueuedCookiesToResponse.php(37): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#34 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle()
#35 /opt/librenms/vendor/laravel/framework/src/Illuminate/Cookie/Middleware/EncryptCookies.php(67): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#36 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\Cookie\Middleware\EncryptCookies->handle()
#37 /opt/librenms/app/Http/Middleware/CheckInstalled.php(61): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#38 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): App\Http\Middleware\CheckInstalled->handle()
#39 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(103): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#40 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/Router.php(693): Illuminate\Pipeline\Pipeline->then()
#41 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/Router.php(668): Illuminate\Routing\Router->runRouteWithinStack()
#42 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/Router.php(634): Illuminate\Routing\Router->runRoute()
#43 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/Router.php(623): Illuminate\Routing\Router->dispatchToRoute()
#44 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(166): Illuminate\Routing\Router->dispatch()
#45 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(128): Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}()
#46 /opt/librenms/vendor/darkghosthunter/larapoke/src/Http/Middleware/LarapokeGlobalMiddleware.php(20): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#47 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): DarkGhostHunter\Larapoke\Http\Middleware\LarapokeGlobalMiddleware->handle()
#48 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TransformsRequest.php(21): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#49 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\Foundation\Http\Middleware\TransformsRequest->handle()
#50 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TransformsRequest.php(21): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#51 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\Foundation\Http\Middleware\TransformsRequest->handle()
#52 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/ValidatePostSize.php(27): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#53 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\Foundation\Http\Middleware\ValidatePostSize->handle()
#54 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/PreventRequestsDuringMaintenance.php(87): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#55 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\Foundation\Http\Middleware\PreventRequestsDuringMaintenance->handle()
#56 /opt/librenms/vendor/fruitcake/laravel-cors/src/HandleCors.php(37): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#57 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Fruitcake\Cors\HandleCors->handle()
#58 /opt/librenms/vendor/fideloper/proxy/src/TrustProxies.php(57): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#59 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Fideloper\Proxy\TrustProxies->handle()
#60 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(103): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#61 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(141): Illuminate\Pipeline\Pipeline->then()
#62 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(110): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter()
#63 /opt/librenms/html/index.php(52): Illuminate\Foundation\Http\Kernel->handle()
#64 {main}
