One last question. Is it even possible to monitor ESXi with LibreNMS? I know the faults with SNMP when it comes to VMware but is there any other way? I’d like to see guest info but I see nothing and SNMP doesn’t pull that in 6.7 at least.
Hi Tomas,
I have successfully done it with 6.5, and it automatically found all the guests and is graphing nicely.
By default SNMP isn’t enabled on ESXi, you may have to enable it first using the esxcli command.
