VPLS services and SAPs
I have several devices from nokias 7210 service access portfolio that are not MPLS capable but still use technology as VPLS and SAP for carrier ethernet.
Whenever librenms discovers one of these devices it correctly reads out all vpls and other service information and stores it in the database. However nothing is diplayed in GUI for that device. Only way to find it is to go via routing > mpls > services and its visible there.
Normally when you have MPLS capable device it will present this information on its own tab within device specific page
Is there a way to present this on specific device page in the gui or where would i need to look in case of trying to improve it myself.
I’m trying to figure this out. Can someone explain what this is “…uuu…uu.uu…uu…uu..u”?
Load disco module core
OS: Nokia SR OS (TiMOS) (timos)
Runtime for discovery module ‘core’: 0.0440 seconds with 441184 bytes
SNMP: [1/0.03s] MySQL: [0/0.00s] RRD: [0/0.00s]
Unload disco module core
Load disco module mpls
MPLS LSPs:
MPLS LSP Paths:
MPLS SDPs:
MPLS Services: ..UU…U.U.UU…UU..UU..UUU.UU..U…U…
MPLS SAPs: …
MPLS SDP Bindings:
MPLS Tunnel Active Routing Hops:
MPLS Tunnel Constrained Shortest Path First Hops:
Runtime for discovery module ‘mpls’: 16.8600 seconds with 2154896 bytes
SNMP: [12/16.76s] MySQL: [25/0.13s] RRD: [0/0.00s]
Unload disco module mpls
Discovered in 17.973 seconds
