VRF support for Juniper MX and QFX series
I would like to have routing instance support for Juniper MX104, 240, 960 and QFX5100 series.
Juniper supports many type of routing instances but the most commonly used that I would LibreNMS to support are: vrf and virtual-switch.
For VRF ( Virtual routing forwarding instance)
  • Discover routing protocol e.g BGP, OSFP,RIP and Interface inside the VRF.
For virtual-switch (Virtual switch routing instance)
  • Discover bridging domain (VLAN / port ) inside the virtual switch
Here is the reference to the Juniper routing instance mib.
https://www.juniper.net/documentation/en_US/junos/topics/concept/mib-support-for-ri-junos-nm.html
/Hien The
Hello @nguyh,
VRF must work for os Junos devices now by default, please test with current
daily version.
With current version Librenms does not detect instance-type virtual-switch and l2vpn. Vrfs are OK.
