VSOL devices
Hi all!!.
Please, can add support for the VSOL OLT Series?
At the moment, it is a generic device in LIBRENMS
Thanks in Advance!
They have added the support for olt but ONU optical power is broken due to some reason
I’m looking for beta testers.
Librenms had support for EPON OLTs from VSOL, I’ve expanded support to GPON OLTs.
The ask would be to either:
  • confirm GPON works for you
  • confirm EPON is not broken after patch
apply patch
scripts/github-apply 19368
remove patch
scripts/github-remove
