WAN link monitoring for Citrix SD-WAN
Hi All,
After much searching for a good network monitoring tool, we discovered LibreNMS. We were very happy to discover that it supports Citrix SD-WAN. There is something that we could do with our old system by monitoring a specific OID which would tell us if a specific WAN link is down. These OIDs are:
1.3.6.1.4.1.3845.31.4.2.2.15.2.1.4 instance x (x being the WAN link number). A value of 4 means it’s up.
To say my coding skill are lacking would be an understatement but I’d be happy to learn how I’d get this added.
I believe the MIBs are already present.
If anybody would be able to help me out with this please that would be great!
Many thanks
Hi @Overthehillsandfaraw
I suggest that you open an issue on github, with all the required informations :
Starting from that, if you would like to do it, we’ll have enough informations to help you start. (considering the number of issues opened, that is probably the faster way).
Bye
