Has anyone created a Weathermap using 95th percentile data over some period of time rather than using current data? I setup Librenms and Weathermap and created a map using the editor but was hoping to make a copy of the map that would give me 95th percentile data over the last week to easily see where more capacity is needed on the network. I thought perhaps I would be able to change the TARGET in the config file but was unsure what to set it to. If anyone has any advice on how to proceed it is appreciated.
