Can anybody help with this error im getting with Weathermap plugin?
/opt/librenms/html/plugins/Weathermap/map-poller.php
PHP Warning: require_once(Console/Getopt.php): failed to open stream: No such file or directory in /opt/librenms/html/plugins/Weathermap/weathermap.php on line 8
PHP Fatal error: require_once(): Failed opening required ‘Console/Getopt.php’ (include_path=’.:/usr/share/pear:/usr/share/php’) in /opt/librenms/html/plugins/Weathermap/weathermap.php on line 8
PHP Deprecated: The each() function is deprecated. This message will be suppressed on further calls in /usr/share/pear/Console/Getopt.php on line 135
Hi Kevin, how are you?
How do you fix the error “PHP Deprecated: The each() function is deprecated. This message will be suppressed on further calls in /usr/share/pear/Console/Getopt.php on line 136”?
thank you!
