Hi guys,
I have a problem with the installation of wethermap.
This is my error.log
script ‘/opt/librenms/html/plugins/index.php’ not found or unable to stat
Can see the editor of weathermap. But i can’t access to the maps because the error.log
I follow step by step the installation of weathermap.
./validate.php
| LibreNMS | 1.48 |
| DB Schema | 2019_02_10_220000_add_dates_to_fdb (132) |
| PHP | 7.2.16-1+0~20190307202206.17+jessie~1.gbpa7be82 |
| MySQL | 10.0.38-MariaDB-0+deb8u1 |
| RRDTool | 1.4.8 |
| SNMP | NET-SNMP 5.7.2.1 |
[WARN] Your database schema has extra migrations (2019_02_10_220000_add_dates_to_fdb). If you just switched to the stable release from the daily release, your database is in between releases and this will be resolved with the next release.
Please your help!
