I have a problem with my weathermap.
He found my librenms’s devices but there are not link :
I installed weathermap and weathermapper
I did device dependencies so why there are not link ?
thank you
thank you
You may have better luck asking the guy who wrote “Weathermapper”
Are all the interfaces being monitored by LibreNMS?
nobody answers on github … there are some issues open without answers
yes they are
Did you try?
You could just make the links by hand…
I did but It’s not synchronized with librenms
Not synchronized? Do they show up on the screen without maps? Are you sure you have the correct link ids?
