Hi
I have installed weathermap but there is problem with link.
When I move mouse arrow over the link in the pop up window see the connected graph.
Unfortunatelly the link box not show the current value of the link ![]()
Any idea ?
Hi
Any idea ?
Make sure you crond.d job is running “/opt/librenms/html/plugins/Weathermap/map-poller.php”
You can try running it manually doing “php /opt/librenms/html/plugins/Weathermap/map-poller.php” and see if the number light up.
after reading other tickets here, try changin:
*/5 * * * * librenms /opt/librenms/html/plugins/Weathermap/map-poller.php >> /dev/null 2>&1
to:
*/5 * * * * librenms php /opt/librenms/html/plugins/Weathermap/map-poller.php >> /dev/null 2>&1
