LibreNMS | 1.53.1
DB Schema | 2019_05_30_225937_device_groups_rewrite (135)
PHP | 7.2.19
MySQL | 5.5.60-MariaDB
RRDTool | 1.7.1
SNMP | NET-SNMP 5.7.2
[OK] Composer Version: 1.8.6
I’m having some troubles with Weathermap. I first noticed the issue after correcting the problem described here: Weathermap editor not working this morning. I cloned the Weathermap repo again and copied in my config files as well as fixing permissions.
After doing this, I can access Weathermap again, but many of the links are grey (not showing the data. Mouse-over or click on links work, and there is data there.
When running /opt/librenms/html/plugins/Weathermap/map-poller.php from the command line, I get the following errors for each link that has an issue:
WARNING: configs//Kalbakken.conf: ReadData: LINK kalbak-sm521009-003-kalbak-sv1-4500-nyb, target: ./kalbak-sm521009-003.tine.no/port-id29212.rrd:INOCTETS:OUTOCTETS on config line 1827 of configs//Kalbakken.conf had no valid data, according to WeatherMapDataSource_rrd
There are hundreds of links with this error, and around 10 - 15 links that show data correctly. The strange thing is that the links that show data are not consistently the same, meaning that links that show data after running map-poller.php might not show data on the next run, and others might start showing data again.
I realize Weathermap is a separate project, but I hope someone here can point me in the right direction for troubleshooting this issue.
