I’m new in librenms. I have installed weathermap and weathermapper plugin.
I would like weathermapper to draw links between the nodes by the decription on ports.
For example, on switches i have two links or more(uplinks and downlinks) with description “uplink-switch-” and “downlink-switch-”. How can i do this?
This is more of WeatherMap question check out https://forum.network-weathermap.com/
Also Weathermapper check here https://github.com/pblasquez/weathermapper
Thx 4 answer. But this is no helpful information
I was trying to point you right direction where your questions could be maybe answerd. Hope you get it figured out.
