I’m just trying to set Weathermaps up for the first time with LibreNMS, I’ve used it before but not with LibreNMS before.
I’ve created a very simple Weathermap to start, just 2 nodes and 1 links but the traffic load stays at 0% (should be around 5-10%).
This is my config, any idea what I’m doing wrong?
Automatically generated by php-weathermap v0.98b
WIDTH 1000
HTMLOUTPUTFILE output/test2.html
IMAGEOUTPUTFILE output/test2.png
KEYPOS DEFAULT 755 64 Traffic Load
KEYTEXTCOLOR 0 0 0
KEYOUTLINECOLOR 0 0 0
KEYBGCOLOR 255 255 255
BGCOLOR 255 255 255
TITLECOLOR 0 0 0
TIMECOLOR 0 0 0
SCALE DEFAULT 0 0 192 192 192
SCALE DEFAULT 0 1 255 255 255
SCALE DEFAULT 1 10 140 0 255
SCALE DEFAULT 10 25 32 32 255
SCALE DEFAULT 25 40 0 192 255
SCALE DEFAULT 40 55 0 240 0
SCALE DEFAULT 55 70 240 240 0
SCALE DEFAULT 70 85 255 192 0
SCALE DEFAULT 85 100 255 0 0
SET key_hidezero_DEFAULT 1
End of global section
TEMPLATE-only NODEs:
NODE DEFAULT
MAXVALUE 100
TEMPLATE-only LINKs:
LINK DEFAULT
BANDWIDTH 100M
regular NODEs:
NODE node07422
LABEL CR01
ICON images/Router.png
POSITION 184 339
NODE 91
LABEL CR02
POSITION 405 339
regular LINKs:
LINK node07422-node07446
INFOURL https://monitoring:443/graphs/type=port_bits/id=11205/
OVERLIBGRAPH https://monitoring:443/graph.php?height=100&width=512&id=11205&type=port_bits&legend=no
TARGET ./cr01/port-id11205.rrd:INOCTETS:OUTOCTETS
NODES node07422 91
BANDWIDTH 1000M
