Hi all, the installation instructions give a list of dependencies to install. Is there a reference for which dependencies are required for the web frontend (i.e. php-fpm) vs the cron scripts?
I am working on a containerized version in which nginx, php-fpm, cron, mariadb, and rrcached all live in separate containers. I would like to keep the images as clean as possible
No list I’m afraid
php-fpm isn’t needed for polling as it’s php-cli stuff. Using the centos install docs:
php70w - all
php70w-cli - all
php70w-gd - web
php70w-mysql - all
php70w-snmp - actually none
php70w-pear - all
php70w-curl - all
php70w-common - all
httpd - web
net-snmp - all
mariadb - db
ImageMagick - web
jwhois - web
nmap - all?
mtr -all?
rrdtool - all
MySQL-python - poller
net-snmp-utils - all
cronie - all
php70w-mcrypt - all
fping - all
git - all
Quick stab at it.
Figured as much. I ended up brute-forcing it, first using validate.php
until it stopped complaining, then confirming that I could run each of the individual cron jobs manually.
Using a ubuntu:16.04
as a base image, I got it down to the following list for the poller image:
cron \
fping \
git \
php7.0-cli \
php7.0-mysql \
php7.0-snmp \
php7.0-curl \
php-net-ipv4 \
php-net-ipv6 \
php7.0-mcrypt \
python \
python-mysqldb \
snmp \
rrdtool \
vim \
Some of those probable aren’t actually needed, but validate.php
complains if they aren’t there.
Next up is to point my web container at php-fpm
and do a similar thing, start adding packages one at a time until the web UI stops throwing errors
