I’ve done a manual update today, and now I cannot even get to the login page on the site.
The update itself had a few errors, summary of what I did as follows:
a) A standard “git pull” would give me two errors regarding conflicts (both of them .gitignore files) , I had to do a “git reset --hard” so I could do the git pull. The git pull itself worked fine.
b) I had some errors/warnings running the daily.sh script, something about Illuminate, Carbon, etc, I can paste the logs if needed, but it worked until the end.
I then did a httpd restart, and now I cannot get the login windows to appear. I don’t have any errors on http log, or /var/log/messages, nothing.
Output from validate also looks fine:
root@ptcitlnms01 librenms]# ./validate.php
| LibreNMS | 1.53.1-23-gfc2f0a4 |
| DB Schema | 2019_05_30_225937_device_groups_rewrite (135) |
| PHP | 7.2.19 |
| MySQL | 5.5.60-MariaDB |
| RRDTool | 1.4.8 |
| SNMP | NET-SNMP 5.7.2 |
[OK] Composer Version: 1.8.6
[root@ptcitlnms01 librenms]#
Any hints ?
