WebUI issue composer missing PHP mysqlnd
Hi Team,
I am writing this topic to help others regards to some issues I had this week and how I resolved that. Thanks to some answers that I could find here.
So I was getting an error on the Web UI and on the server when I ran the command:
./opt/libre/scripts/composer_wrapper.php install
I was coming across an error regards to PHP mysqlnd module missing or not enabled. These were my steps:
1- discover what is the version of your PHP
#php -v
and my version was not the most recent one:
PHP 7.0.31
2- Now, you need to know your version to reinstall/rebuild or in my case swap the package mysqlnd.
update your list of repos just in case
#yum update
yum swap php70w-mysql php70w-mysqlnd
here we swap the packages php70w-mysql and php70w-mysqlnd
*notice that because my PHP is on version 7.0.31, the mysql and mysqlnd are 70w
3- after these commands complete successfully you can run the composer again:
And if the composer doesn’t show any other issues you should get your Web UI back to normal!
Thank you for all the help on the other topics and I hope this simple steps can help someone!
Regards,
