WebUI Validate Config: Failed to load data from backend, check webserver
When trying to validate config on WebUI, it gives me an error: ‘Failed to load data from backend, check webserver.’
I tried Google Chrome and Firefox and it has the same issue. It started a few days back.
./validate.php from console looks fine:
LibreNMS 22.5.0-32-g69a03bd
DB Schema 2022_05_25_090027_drop_widgets_table (241)
PHP 7.3.33
Python 3.6.8
MySQL 10.5.16-MariaDB
RRDTool 1.4.8
SNMP 5.7.2
[OK] Composer Version: 2.3.7
Does anyone have similar problems or know a solution to this?
Thanks in advance
We have the same problem.
same problem here also
Same issue here as well…
i’ve the same issue too, no matter which browser i use : Firefox , Brave, Chrome or Opera.
in my case i thought it was a problem of the varnish cache, since i’ve implemented a varnish service inside the same server , and i was trying to bypass the url from there. also created a section in nginx under conf.d / librenms.conf which would allow that /validate URL , but i ended up on the same result.
Screenshot_1
Same here, using the docker image. The log says
production.ERROR: Undefined offset: 1 {"userId":1,"exception":"[object] (ErrorException(code: 0): Undefined offset: 1 at /opt/librenms/LibreNMS/Validations/WebServer.php:54)"}
still no solutions ?
Mine was fixed, I guess through the updates. I do have an error if I check from the web UI validate:
FAIL: server_name is set incorrectly for your webserver, update your webserver config. ..net parse failure (/validate/results)
Fix:
server_name ..net;
When I run validate from the console there are no errors and I checked the conf file, server name is OK, as suggested in the “Fix”
valide and dailyupdate through command line gives no error. Still the same through GUI
:frowning:
librenms:/opt/librenms$ ./validate.php
LibreNMS 22.6.0
DB Schema 2022_05_30_084932_update-app-status-length (242)
PHP 7.4.29
Python 3.9.7
MySQL 10.5.16-MariaDB-1:10.5.16+maria~focal
SNMP 5.9.1
[OK]
[OK] MySQl and PHP time match
[WARN] IPv6 is disabled on your server, you will not be able to add IPv6
devices.
Before my error changed I did have a problem with “Failed to fetch version from local git: fatal: unrecognized argument: -q” so I followed the solution on this forum and did:
yum -y remove git
yum -y remove git-*
yum -y install https://packages.endpointdev.com/rhel/7/os/x86_64/endpoint-repo.x86_64.rpm
yum install git -y
git --version
git version 2.36.0
Not sure if it had anything to do with this error fixing itself but you can try. I am on Centos 7
I use Docker.
I have been experiencing the same issue since I last installed 22.7.0 Docker Update
Solved mine :
run the following on your root :
pip3 install -r /opt/librenms/requirements.txt
Regards,
Ahsan Muhammad.
Installing the requirements worked for me. For some reason pip wasn’t installed… After installing the requirements, everything is working as it should.
