| LibreNMS | 1.64.1-163-g8e60f8f |
| DB Schema | 2020_05_22_020303_alter_metric_column (168) |
| PHP | 7.3.10 |
| Python | 3.6.8 |
| MySQL | 5.5.64-MariaDB |
| RRDTool | 1.7.1 |
| SNMP | NET-SNMP 5.7.2 |
[OK] Composer Version: 1.10.7
When creating maintenance I’ve tried several different ways to create recurring maintenance and check several days in the maintenance, after creation the boxes disappear and no days are checked, in the images below I’ve tried with no end date and also I have tried with an end date, the results are the same.
Here is an example I began to create
After saving this is how it appears in the maintenance section
When I open the alert schedule up it looks like this
Any help would be greatly appreciated as I just deleted all my maintance schedules due to an issue with them all using UTC time for some reason (thats a totally different issue and not as critical)
