How to add alert role for CCQ ,or what specific entry can i add it ?
what is CCQ ?
You should use the Wireless Sensors, the documentation is available here:
https://docs.librenms.org/#Developing/os/Wireless-Sensors/
You need to add alert rules from the collection based on this sensor and you can edit device-specific information under the device setting (like the CCQ, if supposed).
Client Connection Quality for Wireless AP.
YES ,Ok , I want to create roule ccq , like “processors.processor_usage” but i don’t know Entry of CCQ ?
OR watch one of them i can’t find “WirelessCcqDiscovery”
try out this video -> https://youtu.be/ryv0j8GEkhM
https://docs.librenms.org/#Alerting/Rules/
i will need to play around with the rules in order to make a suggest for you -
