Hi guys, can not find any examples and nothing related in offcial documentation , so I will post question here.
Is it possible to change icon file , icon color , or any attribute when device is down ?
So far I can change link color according to value but would like to add this feature to my map so I can see when device is down.
Any feedback would be preciated:
Regards.
Leandro.
I know it works on 0.98 but I havenât tested it with LibreNMS version which I believe is 0.97 but you should be able to check out the 0.97 docs and see if itâs there or not.
Node config example
NODE node05268bis
ICON images/port_{node:this:inscaletag}.png
TARGET xxxxxxxxx
USESCALE ifstatus in percent
POSITION 321 280
So if you look at the scale, after the RGB there is a"1" or â2â right?
Now if you look at the nodeâs config, thatâs where you tell wheathermap what picture to use and the âinscaletagâ does the trick. Of course youâll need to have an image file named, as per my example, âport_1.pngâ and âport_2.pngâ and maybe also a âport_unknown.pngâ.
