When adding a disk in an empty slot, it gives a temperature warning
I added a disk to a QNAP TurboNAS 4.3.4, slot was empty, and LibreNMS started giving sensor over limit alerts:
After manually changing the threshold it stopped alerting:
This is not a bug report, I just thought it was funny. Normally, if a disk suddenly gets +30 degrees hotter I’d like to know. :slight_smile:
Hi @RaymiiOrg
If QNAP doesnt report limits by snmp, librenms calculates them with +/- “X” from actual value. As your value was 0º, limits are near 0º so 29ºC over it.
I suspected that, and since the slot was empty when the device was added, I understand what happened. I just thought it was nice.
