well, i maybe solved the issue
but on hacky way
i know what is the problem
the whole IPv6 stack is affected !!!
but need help
where is $device[‘context_name’] set first time ?
after few day of debugging i lost my eyes ![]()
but on hacky way
but need help
yes
definitive
problem is that recent LNMS
the root of problem is in database
table “ipv6_addresses” have incorect value in “context_name” cell
and
/includes/discovery/functions.php
function discover_process_ipv6(&$valid, $ifIndex, $ipv6_address, $ipv6_prefixlen, $ipv6_origin, $context_name = ‘’)
update table with $device[‘context_name’] which is not NULL , it is “”
but function try after that to match NULL from DB
so, if anyone could help, where is $device[‘context_name’] set first ?
found it
includes/discovery/ipv6-addresses.inc.php
@murrant @Jellyfrog
is this is acceptable as FIX/PR ??
foreach (DeviceCache::getPrimary()->getVrfContexts() as $context_name) {
+ //empty string instead of NULL
+ $context_name = ($context_name == NULL) ? '' : $context_name;
$device['context_name'] = $context_name;
tested on updated LNMS ubuntu 20.04 / mysql 8.0.27 in ← production
tested on virgin LNMS ubuntu 20.04 / mariadb Ver 15.1 ← test lab
problem was that ipv6_addresses table was not populated with proper ipv6_network_id because of NULL/empty string mismatch
that caused whole trouble with ipv6 address missing / cross connecting because every ipv6_address was in same (empty) ipv6_network_id
now it is OK
I’m confused. Do you want null or not?
$context_name = $context_name ?? ""
old fashioned ![]()
if ($device_context == NULL) {
$device_context = ''
no, i don’t want null
empty string is needed
We should use null were possible tho.
this is the root of problems
// Update IPv6 network ID if not set
if ($context_name == null) {
$ipv6_network_id = dbFetchCell('SELECT `ipv6_network_id` FROM `ipv6_networks` WHERE `ipv6_network` = ? AND `context_name` IS NULL', [$ipv6_network]);
} else {
IS NULL
it is never be NULL because
} else {
//Update Context
dbUpdate(['context_name' => $device['context_name']], 'ipv6_networks', '`ipv6_network` = ?', [$ipv6_network]);
echo 'n';
is constantly updated with not null value (empty string)
two $context_name does not match
one from $device, other on function input
that is why i propose
//empty string intead of NULL
and we never hit NULL condition
it could be removed completly from functions.inc.php
I suggest fixing the source instead of patching the symptom then
well …
i think i done my job here
opened issue 24 days ago
nobody reacted
proved that this error does not exists in older LNMS
tracked down where is error
reversing from “why WEB does not show IPv6” and going backward
find the root cause
if i need to make my tip,
PR Common contexts for polling (#13158)
there was introduced
public function getVrfContexts(): array
return $this->vrfLites->isEmpty() ? [’’] : $this->vrfLites->pluck(‘context_name’)->all();
so, from my point of view, i done my job
maybe you or other skilled PHP programmer could solve this
after all, it is huge drawback that IPv6 stack is not functioning in LNMS
FYI in PHP null == '' is true.
Also, if you were to update the SQL queries to use Laravel Fluent/Eloquent, it would fix the issue automatically because it builds the queries to correctly handle null or ‘’.
so, from my point of view, i done my job Who is going to finish the “job” then?
yes @murrant , wrong copy/paste
space is left out
whatever
ok, will see,
is App\Models\Ipv6xxxx already in function ?
like Vlans ?
ok
made it with Laravel syntax
looks like it is working
few day test, will send PR
