I’ve noticed that LibreNMS’ virtual memory usage is constantly increasing, until it reaches near-100% usage. Here’s a screenshot showing virtual memory usage for the last month. The drops are after a LibreNMS reboot.
Is that normal behavior?
You need to take a look at the usage from tools within your server (such as ps and top etc)
LibreNMS itself does not have long running processes, so it is unlikely this is LibreNMS.
Thank you for your reply. I just noticed something else:
I just rebooted the host running LibreNMS and ran ps aux --sort=-vsz. Here are the top 20 consumers, sorted by virtual memory consumption (VSZ):
USER PID %CPU %MEM VSZ RSS TTY STAT START TIME COMMAND
root 1252 0.0 0.1 1917028 29388 ? Sl 09:34 0:00 /snap/amazon-ssm-agent/11321/ssm-agent-worker
root 652 0.1 0.2 1847320 35416 ? Ssl 09:34 0:01 /usr/lib/snapd/snapd
root 644 0.0 0.1 1832668 18984 ? Ssl 09:34 0:00 /snap/amazon-ssm-agent/11321/amazon-ssm-agent
mysql 948 1.9 1.6 1690640 272696 ? Ssl 09:34 0:14 /usr/sbin/mariadbd
librenms 860 0.8 0.0 1354200 11256 ? Ssl 09:34 0:06 /usr/bin/rrdcached -B -F -R -w 1800 -z 1800 -t 4 -b /opt/librenms/rrd/ -j /var/lib/rrdcached/journal/ -G librenms -U librenms -p /run/rrdcached.pid -s librenms -l unix:/run/rrdcached.sock
librenms 16585 0.7 0.2 1305844 35564 ? Sl 09:45 0:00 python3 /opt/librenms/poller-wrapper.py 16
root 699 0.0 0.0 472656 12676 ? Ssl 09:34 0:00 /usr/libexec/udisks2/udisksd
root 833 0.0 0.0 398868 11812 ? Ssl 09:34 0:00 /usr/sbin/ModemManager
polkitd 634 0.0 0.0 384672 8908 ? Ssl 09:34 0:00 /usr/lib/polkit-1/polkitd --no-debug
root 224 0.0 0.1 290148 26132 ? SLsl 09:34 0:00 /sbin/multipathd -d -s
librenms 772 0.1 0.3 243080 58520 ? S 09:34 0:00 php-fpm: pool librenms
librenms 963 0.0 0.3 242956 55196 ? S 09:34 0:00 php-fpm: pool librenms
librenms 771 0.0 0.3 242844 56196 ? S 09:34 0:00 php-fpm: pool librenms
root 630 0.0 0.1 237200 30756 ? Ss 09:34 0:00 php-fpm: master process (/etc/php/8.3/fpm/php-fpm.conf)
syslog 731 0.0 0.0 222816 4960 ? Ssl 09:34 0:00 /usr/sbin/rsyslogd -n -iNONE
librenms 16610 0.4 0.4 150896 74388 ? S 09:45 0:00 php /opt/librenms/lnms device:poll 44 -q
librenms 16630 0.4 0.4 148784 71960 ? S 09:45 0:00 php /opt/librenms/lnms device:poll 14 -q
librenms 16609 0.3 0.4 146736 70656 ? S 09:45 0:00 php /opt/librenms/lnms device:poll 9 -q
librenms 16615 0.2 0.4 146736 70580 ? S 09:45 0:00 php /opt/librenms/lnms device:poll 80 -q
librenms 16616 0.2 0.4 146736 70532 ? S 09:45 0:00 php /opt/librenms/lnms device:poll 26 -q
If you sum the numbers in the VSZ column, you get 13,422,828 (i.e. 13,4G).
However, the server stats widget shows 1871 Mbytes of virtual memory usage:
The same number is reported by LibreNMS :: Memory Pool :: Virtual memory :: Usage:
Am I misinterpreting something or is this a bug?
This is the wrong field to even analyze what you are positing is an issue. https://www.baeldung.com/linux/process-memory-management
RSS would be more appropriate.
Total Memory Usage by Included Processes:
11,256 + 35,564 + 56,196 + 58,520 + 55,196 + 70,656 + 74,388 + 70,580 + 70,532 + 71,960 + 272,696 + 4,960 = 852,504 KB (approximately 852.5 MB)
At this snapshot in time.
