Widget "Device Geo Locations" where to find it?
I am a bit new to LibreNMS. An old install of LibreNMS has the widget “Devices Geo Locations”, however the new installation does not.
Where would i find this widget at? Here is the drop down menu and the background on the left side is the actual widget.
Libre%20Widget
Also there are additional no plugins listed in the GUI.
Do you need any other info from me to help figure this out?
Thanks in advance
Erik
Huh, never seen that before… You sure someone didn’t write some custom code for that install?
If is might be a custom written widget, do you know what directory I might find it in? I have to be physical in front of the server to work on it, there is no remote access. Just trying to get as much info before I have to go on site.
This is also a environment that I didn’t install.
