I would like to ask for help.
I have a Mikrotik AP and I added to my own LibreNMS setup. Everything looks good but wireless client count diagrams are empty all the time.
Does anyone know why these are empty? And how can I collect this information from the AP?
Regards,
Imre
./validate your install run and post.
./validate.php
and pastebin
./poller.php -h HOSTNAME -d
Thanks for the really quick reply.
Validate output:
Firstly, I got this:
Component |
Version |
LibreNMS |
1.38-14-g831bd01 |
DB Schema |
247 |
PHP |
7.0.28-0ubuntu0.16.04.1 |
MySQL |
10.0.34-MariaDB-0ubuntu0.16.04.1 |
RRDTool |
1.5.5 |
SNMP |
NET-SNMP 5.7.3 |
[OK] Composer Version: 1.6.3
[FAIL] Database: incorrect column (notifications/datetime)
[FAIL] Database: incorrect column (users/created_at)
[FAIL] We have detected that your database schema may be wrong, please report the following to us on IRC or the community site (Report database schema issues here - LibreNMS Community):
SQL Statements:
ALTER TABLE notifications
CHANGE datetime
datetime
timestamp NOT NULL DEFAULT ‘1970-01-02 00:00:00’ ;
ALTER TABLE users
CHANGE created_at
created_at
timestamp NOT NULL DEFAULT ‘1970-01-02 00:00:01’ ;
[WARN] Your install is over 24 hours out of date, last update: Fri, 06 Apr 2018 03:09:27 +0000
After that, I made the suggested modifications on the database, so now I get this:
Component |
Version |
LibreNMS |
1.38-14-g831bd01 |
DB Schema |
247 |
PHP |
MySQL |
RRDTool |
1.5.5 |
SNMP |
NET-SNMP 5.7.3 |
Poller.php output
It looks like you device is returning bad SNMP data 0 for clients?
Hmm, I see. It’s interesting.
I use CAPsMAN to AP management so I think maybe this can be a problem.
I dont believe the CAPSman OIDs have been implemented. Unfortunately i don’t have the knowledge to implement it.
See below from mikrotik MIB.
mtxrWlCMRtabEntry OBJECT-TYPE
SYNTAX MtxrWlCMRtabEntry
MAX-ACCESS not-accessible
STATUS current
DESCRIPTION "Wireless CAPSMAN registration table. It is indexed by remote
mac-address and local interface index"
INDEX { mtxrWlCMRtabAddr, mtxrWlCMRtabIface }
::= { mtxrWlCMRtabTable 1 }
MtxrWlCMRtabEntry ::= SEQUENCE {
mtxrWlCMRtabAddr MacAddress,
mtxrWlCMRtabIface ObjectIndex,
mtxrWlCMRtabUptime TimeTicks,
mtxrWlCMRtabTxBytes Counter32,
mtxrWlCMRtabRxBytes Counter32,
mtxrWlCMRtabTxPackets Counter32,
mtxrWlCMRtabRxPackets Counter32,
mtxrWlCMRtabTxRate Gauge32,
mtxrWlCMRtabRxRate Gauge32,
mtxrWlCMRtabTxStrength Integer32,
mtxrWlCMRtabRxStrength Integer32,
mtxrWlCMRtabSsid DisplayString
Dear All,
I also need to fetch Client Device data connected with Master Device using WiRemoteNodeStatsEntryTable,
This includes,
MacAddress
Node Association
Tx Bytes
Rx Bytes
Signal Level
Noise Level
Kindly provide some method to do this.
Thanks,
Good evening, if you can manage to get capsman data in librenms?
