Is There any solutions for this ?
Also I’m getting errors when I execute daily.sh
$ ./validate.php
PHP Fatal error: Composer detected issues in your platform: Your Composer dependencies require the following PHP extensions to be installed: curl, dom, gd, xml. in /opt/librenms/vendor/composer/platform_check.php on line 47
Daily.sh errors
$ ./daily.sh
Fetching new release information OK
Between releases, waiting for newer release
Updating Composer packages FAIL
Verifying lock file contents can be installed on current platform.
Your lock file does not contain a compatible set of packages. Please run composer update.
Problem 1
- Root composer.json requires PHP extension ext-curl * but it is missing from your system. Install or enable PHP’s curl extension.
Problem 2
- Root composer.json requires PHP extension ext-gd * but it is missing from your system. Install or enable PHP’s gd extension.
Problem 3
- Root composer.json requires PHP extension ext-xml * but it is missing from your system. Install or enable PHP’s xml extension.
Problem 4
- amenadiel/jpgraph is locked to version 3.6.14 and an update of this package was not requested.
- amenadiel/jpgraph 3.6.14 requires ext-gd * → it is missing from your system. Install or enable PHP’s gd extension.
Problem 5
- tijsverkoyen/css-to-inline-styles is locked to version 2.2.3 and an update of this package was not requested.
- tijsverkoyen/css-to-inline-styles 2.2.3 requires ext-dom * → it is missing from your system. Install or enable PHP’s dom extension.
Problem 6
- laravel/framework v8.40.0 requires tijsverkoyen/css-to-inline-styles ^2.2.2 → satisfiable by tijsverkoyen/css-to-inline-styles[2.2.3].
- laravel/framework is locked to version v8.40.0 and an update of this package was not requested.
To enable extensions, verify that they are enabled in your .ini files:
- /etc/php/8.0/cli/php.ini
- /etc/php/8.0/cli/conf.d/10-opcache.ini
- /etc/php/8.0/cli/conf.d/10-pdo.ini
- /etc/php/8.0/cli/conf.d/20-bz2.ini
- /etc/php/8.0/cli/conf.d/20-calendar.ini
- /etc/php/8.0/cli/conf.d/20-ctype.ini
- /etc/php/8.0/cli/conf.d/20-exif.ini
- /etc/php/8.0/cli/conf.d/20-ffi.ini
- /etc/php/8.0/cli/conf.d/20-fileinfo.ini
- /etc/php/8.0/cli/conf.d/20-ftp.ini
- /etc/php/8.0/cli/conf.d/20-gettext.ini
- /etc/php/8.0/cli/conf.d/20-iconv.ini
- /etc/php/8.0/cli/conf.d/20-mbstring.ini
- /etc/php/8.0/cli/conf.d/20-phar.ini
- /etc/php/8.0/cli/conf.d/20-posix.ini
- /etc/php/8.0/cli/conf.d/20-readline.ini
- /etc/php/8.0/cli/conf.d/20-shmop.ini
- /etc/php/8.0/cli/conf.d/20-sockets.ini
- /etc/php/8.0/cli/conf.d/20-sysvmsg.ini
- /etc/php/8.0/cli/conf.d/20-sysvsem.ini
- /etc/php/8.0/cli/conf.d/20-sysvshm.ini
- /etc/php/8.0/cli/conf.d/20-tokenizer.ini
You can also run php --ini inside terminal to see which files are used by PHP in CLI mode.
Updated from unset to OK
Updating SQL-Schema FAIL
Updating submodules OK
Cleaning up DB FAIL
Fetching notifications FAIL
Caching PeeringDB data FAIL
Caching Mac OUI data FAIL
And librenms.log file
root@zeus:/opt/librenms/logs# tail librenms.log
#88 /opt/librenms/vendor/fruitcake/laravel-cors/src/HandleCors.php(37): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#89 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Fruitcake\Cors\HandleCors->handle()
#90 /opt/librenms/vendor/fideloper/proxy/src/TrustProxies.php(57): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#91 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Fideloper\Proxy\TrustProxies->handle()
#92 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(103): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#93 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(141): Illuminate\Pipeline\Pipeline->then()
#94 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(110): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter()
#95 /opt/librenms/html/index.php(52): Illuminate\Foundation\Http\Kernel->handle()
#96 {main}
