- The output of
./validate.php
If it’s an issue with the WebUI then please consider including the browser version you are using.
Hi Guys, workstation is showing as down in snmp check even though it is connected to wifi. As i am new to librenms. could u please help me out.
that means you have not configured SNMP correctly on the workstation or when you added the host you didn’t use the correct community string that you set up.
https://docs.librenms.org/#Support/Adding-a-Device/
Hi Kevin,
But the same snmp is able to detect on the LAN. But when it is moved out of LAN and connected to wifi it is showing as down.
then that is something to do with your wifi. not SNMP or librenms. You need to troubleshoot further.
