World Map Not displaying Nodes
I have the gps coordinates entered into the location of each device [xx.xxxxx,-96.xxxxxx]. When I goto each device and click on “map”, it takes me to the location in google maps. I have a dashboard for the globe map but it is not showing the nodes. I was getting the blank screen and went through and removed the extra spaces from the device location field but I was still getting a error. It does not seem to like disabled devices. The console was showing a error that “Nan” is not defined. I saw what devices were listed as nan and it was the ones I had disabled. I enabled them to clear the error and now I can see the globe map (its a faint background image) but none of the nodes are showing up and nothing happens when I click on the map.
For the dashboard widget don’t use globe map instead use the world map.
Globe map is buggy and being phased out.
Got it. Thank you Kevin
