This thing has been bugging me for a while…values for nokia isam dbm pon sensor limits are wrong.
When you go to “Edit” > “health” you’ll find this
Clearly values for high and low are way off.
I looked at github source files and found some examples under tests/data/nokia-isam.json. Here is the snippet:
“sensor_deleted”: 0,
“sensor_class”: “dbm”,
“poller_type”: “snmp”,
“sensor_oid”: “.1.3.6.1.4.1.637.61.1.56.5.1.6.4355.2”,
“sensor_index”: “lt:1/1/1/2-tx”,
“sensor_type”: “nokia-isam”,
“sensor_descr”: “lt:1/1/1/2 Tx Power”,
“group”: null,
“sensor_divisor”: 1,
“sensor_multiplier”: 1,
“sensor_current”: -5.49,
“sensor_limit”: -3,
“sensor_limit_warn”: -4,
“sensor_limit_low”: -9,
“sensor_limit_low_warn”: -8,
“sensor_alert”: 1,
“sensor_custom”: “No”,
“entPhysicalIndex”: null,
“entPhysicalIndex_measured”: null,
“sensor_prev”: null,
“user_func”: null,
“state_name”: null
“sensor_oid”: “.1.3.6.1.4.1.637.61.1.56.5.1.6.4356.1”,
“sensor_index”: “lt:1/1/2/1-tx”,
“sensor_descr”: “lt:1/1/2/1 Tx Power”,
“group”: null,
“sensor_current”: 3.66,
“sensor_limit”: 7,
“sensor_limit_warn”: 6,
“sensor_limit_low”: -0.5,
“sensor_limit_low_warn”: 0.5,
“sensor_alert”: 1,
“user_func”: null,
“state_name”: null
The lower part containes the sensor limit values that should be displayed in my screenshot. What i don’t understand is why both test examples show tx values? seems odd to me.
Problem with all of this is that limit values are wrong and marked in red which is inaccurate. This is true only for pon ports as far as i can see.
