21.1.0
(2021-02-02)
A big thank you to the following 37 contributors this last month:
- murrant (14)
- Jellyfrog (8)
- efelon (4)
- SourceDoctor (4)
- paulierco (4)
- TheMysteriousX (3)
- dependabot (3)
- crazy-max (2)
- djamp42 (2)
- jezekus (2)
- martijn-schmidt (2)
- vitalisator (2)
- hanserasmus (1)
- lukoramu (1)
- deveth0 (1)
- lazyb0nes (1)
- mpikzink (1)
- richardlawley (1)
- Torch09 (1)
- rk4an (1)
- FingerlessGlov3s (1)
- dlehman83 (1)
- fablabo (1)
- zerrac (1)
- loopodoopo (1)
- alakiza (1)
- yrebrac (1)
- nkringle (1)
- ottorei (1)
- Senetus (1)
- WhippingBoy01 (1)
- haydenseitz (1)
- admish (1)
- kedare (1)
- ah9828 (1)
- OahzEgroeg (1)
- Dmkaz (1)
Feature
- Show Device Group on Map (#12379) - SourceDoctor
Security
Device
- Update enexus for “SmartPack S” (#12465) - haydenseitz
- Added Firepower 4125 (#12462) - WhippingBoy01
- Add Alcatel AOS7 bgpdescr & bgpprefix (#12450) - paulierco
- Panduit PDU (#12449) - Senetus
- Add sensors for Meinberg Lantime NTP-devices (#12447) - ottorei
- Adds tripplight snmpwebcard support (#12445) - nkringle
- Add mempools, cpu and storage to some arbor devices (#12444) - TheMysteriousX
- Filter Juniper mempools (#12443) - TheMysteriousX
- Add planet-pdu os device (#12441) - paulierco
- Add WTI POWER os device (#12440) - jezekus
- Enumerate sensors under the Outlet for the entity-physical inventory (#12439) - martijn-schmidt
- Nokia sap graph (#12432) - loopodoopo
- Apc epdu (#12428) - zerrac
- Fix for Mikrotik SwOS discovery (#12426) - jezekus
- New device OS: McafeeWebGateway (#12418) - paulierco
- Make LibreNMS recognize Schleifenbauer model DPM27/E with existing OS definition (#12414) - martijn-schmidt
- Update OPNsense version Regex, for _ releases (#12407) - FingerlessGlov3s
- Change raspberry_pi_sensors state (#12390) - mpikzink
- Added support for Motorola and Thomson DOCSIS Cable Modems. (#12386) - lukoramu
- Check Point: Added HA state support (#12382) - lazyb0nes
- Add Zyxel IES 5206 and 5212 to supported Devices (#12373) - Torch09
- Alcatel-Lucent support part2 (#12369) - paulierco
- Eltek Enexus. Disable some battery sensors if no battery bank is installed at all. (#12367) - vitalisator
- New device os Raisecom Router OS (ROAP) (#12361) - vitalisator
- Freenas storage polling fix (#12275) - Dmkaz
Webui
- Fix exception in device overview puppet widget (#12474) - murrant
- Support new lines in login_message again (#12469) - efelon
- Fix poller frequency display bug and warn (#12466) - murrant
- Remove unnecessary horizontal scroll bars in allert widgets (#12464) - efelon
- Reintroduce word wrapping to the custom login message (#12460) - efelon
- Add a button to reset port state history (#12457) - TheMysteriousX
- Improving readability of tables on dark theme dashboards (#12455) - efelon
- Changed default param max_rows to increase widget count on dashboard (#12438) - alakiza
- Fix percent bar text location (#12406) - rk4an
- Don’t show geolocation on snmp location string (#12384) - SourceDoctor
- Copy Dashboard to other User (#11989) - SourceDoctor
- Output image for graphs with no data (#11865) - murrant
Authentication
Api
- Fix oxidized API call when config is missing (#12476) - murrant
- Allow logs to be filtered by min/max id (#12471) - kedare
Bug
- Fix broken statement on auto discovery (#12408) - djamp42
- Remove unused openssl_ver (#12378) - murrant
- Fix version compare (#12376) - murrant
Documentation
- Update Rancid.md (#12487) - fablabo
- Creating Documentation page (#12486) - yrebrac
- Added missing / on internal link (#12467) - admish
- Lnms link in /usr/bin (#12446) - murrant
- Update Documentation (#12411) - dlehman83
- Document flattened Inventory API function (#12404) - richardlawley
- Update docs for raspberry.sh (#12389) - deveth0
- Update to incorporate new locking mechanisms (#12388) - hanserasmus
- Update Distributed-Poller.md Discovery using dispatcher service (#12387) - djamp42
- Doc - Increase Nginx Timeout (#12368) - SourceDoctor
Tests
- Add test to check if os parameter matches filename (#12442) - Jellyfrog
- Remove Travis support (#12416) - crazy-max
- GitHub Actions dev:check ci (#12392) - crazy-max
Misc
- Cast REDIS_TIMEOUT to integer (#12482) - OahzEgroeg
- Redis - Add scheme to allow TLS (#12477) - ah9828
Dependencies
- Remove PHP8 blockers in LibreNMS (#12451) - murrant
- Bump laravel/framework from 8.21.0 to 8.22.1 (#12448) - dependabot
- Update php dependencies (#12425) - murrant
- Upgrade to Laravel Mix 6 (#12421) - Jellyfrog
- Bump axios from 0.19.2 to 0.21.1 (#12420) - dependabot
- Bump ini from 1.3.5 to 1.3.8 (#12395) - dependabot
