21.6.0
(2021-06-17)
A big thank you to the following 23 contributors this last month:
- mpikzink (9)
- murrant (6)
- PipoCanaja (5)
- dust241999 (3)
- mathieu-artic (2)
- paulierco (2)
- paddy01 (2)
- andrzejmaczka (2)
- zombah (1)
- BennyE (1)
- Sea-n (1)
- jbronn (1)
- d-k-7 (1)
- systemcrash (1)
- loopodoopo (1)
- maesbrisa (1)
- thomseddon (1)
- cliffalbert (1)
- Jellyfrog (1)
- wolfraider (1)
- rpardim (1)
- geg347 (1)
- ottorei (1)
- Jellyfrog (31)
- PipoCanaja (15)
- murrant (10)
- tayyabali785 (1)
Feature
- New module add juniper rpm support + reimplementation of cisco-sla module (#12799) - geg347
- ISIS-adjacency polling support (#12461) - ottorei
Device
- Add Serialnumber for some Dell ForceTen devices (#12960) - mpikzink
- 2 more Rittal variants (#12953) - mpikzink
- Added New-OS: Alcatel-Lucent Enterprise Stellar Wireless (#12952) - BennyE
- Add SDSL Support for OneAccess routers (#12948) - mathieu-artic
- Improve TP-Link JetStream Discovery (#12946) - jbronn
- Alcatel-Lucent aos6 and aos7 fdb fix (#12945) - paulierco
- Janitza UMG96 (#12944) - mpikzink
- Imporoved raritan pdu support (#12937) - d-k-7
- Alcatel-Lucent Aos7 sensors nobulk (#12935) - paulierco
- Add Epson Projector as new OS (#12928) - mpikzink
- Add Barco Clickshare (#12927) - mpikzink
- Fix nokia(TiMOS) memory (#12925) - paddy01
- Device - Vertiv-PDU - Issue 11608 (#12923) - dust241999
- Adding basic support for Vertiv PDUs and power graphs (#12908) - dust241999
- Ciena 6500 (#12903) - loopodoopo
- Added support for PowerWalker VFI (#12891) - andrzejmaczka
- Initial HAProxy ALOHA support (#12889) - Jellyfrog
- HWG WaterLeak sensor support (#12865) - PipoCanaja
- Added definition for Riello 204 (#12861) - wolfraider
- Add support for oneaccess router (#12850) - mathieu-artic
- Gaia VPN IPSEC discovery (#12823) - rpardim
Webui
- Human readable database inconsistent error (#12950) - murrant
- Add TopErrors widget based on ifError_rate (#12926) - PipoCanaja
- Fix “Sub-directory Support” in small steps (#12911) - mpikzink
- Fix “Sub-directory Support” in small steps (#12910) - mpikzink
- Fix “Sub-directory Support” in small steps (#12905) - mpikzink
- FIX Alert rules: Import from Alert Rule (#12897) - andrzejmaczka
- Fix port down alert toggle (#12884) - murrant
Authentication
Applications
Api
Alerting
- Add Signal CLI transport support (#12954) - mpikzink
- Update device_component_down_junos macro (#12898) - thomseddon
Discovery
- LLDP - ifAlias should be last checked in function find_port_id (#12904) - PipoCanaja
- LLDP - Extend discovery lldp code to support different subtypes (#12901) - PipoCanaja
Polling
Rancid
- Support for fortiswitch in gen_rancid (#12894) - cliffalbert
Refactor
- Filter unwanted data in Routes Ajax reply (#12847) - PipoCanaja
