21.9.0
(2021-09-16)
A big thank you to the following 20 contributors this last month:
- murrant (29)
- Jellyfrog (5)
- ottorei (3)
- SourceDoctor (3)
- Galileo77 (2)
- paulierco (2)
- Fehler12 (2)
- Negatifff (2)
- deajan (2)
- mpikzink (2)
- vakartel (2)
- efelon (1)
- pimvanpelt (1)
- kimhaak (1)
- kevinwallace (1)
- noaheroufus (1)
- si458 (1)
- mzacchi (1)
- niddey (1)
- PipoCanaja (1)
- Jellyfrog (21)
- murrant (19)
- ottorei (3)
- SourceDoctor (2)
- PipoCanaja (2)
- mpikzink (1)
Feature
- API alert transport can include Options variables in the Body for POST requests (#13167) - mzacchi
- Show port speed on port graphs, optionally set scale (#11858) - murrant
Device
- Fix Dell server sensors (#13247) - murrant
- Add mouseover mini graphs that makes sense for Liebert PDU (#13246) - Galileo77
- Add ifName to osag os (#13243) - paulierco
- IfName to mcafeewebgateway (#13242) - paulierco
- Add VPP logo (#13230) - pimvanpelt
- Add Support for USW-Flex (#13229) - Fehler12
- Added Cisco CBS 250 Support (#13228) - Fehler12
- Update geist-watchdog.yaml (#13223) - Galileo77
- Add skip_values to Liebert capacity sensor definitions (#13200) - kevinwallace
- Procurve add SysDescr Regex (#13196) - mpikzink
- Updated OS Support: Dragonwave Horizon (#13193) - noaheroufus
- ZTE ZXR10 define discovery for mempool and processor (#13192) - vakartel
- Dell Network Virtual Link Trunk Status (#13162) - mpikzink
Webui
- Update to fix table row color and hover color for dark.css (#13244) - efelon
- Fix port minigraph layout (#13240) - murrant
- Sort dashboard entries alphabetically (#13238) - ottorei
- Fix graph row columns (#13232) - murrant
- Changed map functionality in device overview (#13225) - kimhaak
- New Blade Components: x-device-link, x-port-link, x-graph-row, x-popup (#13197) - murrant
- Add serial search in ajax search process (#13185) - Negatifff
- Allow device actions to appear in device list and improve docs (#13177) - murrant
- Show count of Ports in PortGroup display (#13164) - SourceDoctor
- Change automatic widget updates to use bootgrid when possible (#13159) - niddey
Alerting
- Fix PagerDuty transport’s group field (#13235) - ottorei
- Format port speed changes in the event log (#13174) - murrant
Graphs
Settings
- Dynamic Select setting (#13179) - murrant
- Increase config value length limit (#13178) - murrant
- Default port group in Settings (#13175) - SourceDoctor
- Default port_group for new ports (#13166) - SourceDoctor
- Add support for description texts in Settings page (#13104) - Jellyfrog
Discovery
- Mark snmp disabled devices as skipped (#13202) - murrant
- Allow more compatibility in STP port discovery/polling (#13109) - PipoCanaja
Polling
- Fix snmp_bulk setting not being applied (#13209) - murrant
- Do not poll passive ISIS-circuits (#13168) - ottorei
- Common contexts for polling (#13158) - murrant
- Rewrite ISIS Adjacency discovery/polling (#13155) - murrant
Oxidized
Bug
- Fix mempool unit display (#13241) - murrant
- Select dynamic fixes (#13187) - murrant
- Validate schema in utc (#13182) - murrant
- Fix DB Inconsistent friendly error message (#13163) - murrant
Refactor
- Update configuration docs to use lnms config:set (#13157) - murrant
- Rename nobulk -> snmp_bulk (#13098) - Jellyfrog
Documentation
- Add security context service (#13218) - deajan
- Fix numbering in application docs (#13183) - si458
- Docs link to webui settings in user’s install (#13176) - murrant
