22.1.0
(2022-01-23)
A big thank you to the following 26 contributors this last month:
- murrant (9)
- Npeca75 (4)
- loopodoopo (3)
- ilGino (2)
- Jellyfrog (2)
- SourceDoctor (2)
- laf (2)
- aztec102 (2)
- twelch24 (1)
- tkjaer (1)
- ssasso (1)
- TechieDylan (1)
- hvanoch (1)
- h-barnhart (1)
- gdepeyrot (1)
- k0079898 (1)
- efelon (1)
- westerterp (1)
- avermeer-tc (1)
- Fehler12 (1)
- bonzo81 (1)
- glance- (1)
- VirTechSystems (1)
- iopsthecloud (1)
- blubecks (1)
- thford89 (1)
- murrant (22)
- Jellyfrog (13)
- laf (10)
- PipoCanaja (6)
- ottorei (2)
- SourceDoctor (2)
Feature
- Add Sla jitter packet loss percent graph (#13600) - bonzo81
- Add API-routes for listing MPLS SAPs and services (#13561) - blubecks
Device
- Merge enviromux-micro in existing NTI (#13696) - Npeca75
- Change the variable to detect version for mikrotik ups runtime device divisor (#13678) - TechieDylan
- VRP BGP fixes (#13675) - murrant
- Added new sensors to mes23xx (#13671) - Npeca75
- Added initial detection MES2324F or MES2324FB (#13669) - aztec102
- New OS: Adva XG 304 (#13668) - h-barnhart
- Basic ZTE ZXA10 detection (#13658) - murrant
- Added CET Power T2S TSI (#13645) - aztec102
- Eltek ospf poller disable (#13635) - loopodoopo
- Smartoptics dcp m 40 zr (#13634) - avermeer-tc
- Updated XOS (Extreme) processor data to use correct OID (#13633) - laf
- Initial Support for Fujitsu RX300 with iRMC4 (#13631) - Fehler12
- Teleste Luminato ports & qam/asi output sensors & yaml (#13616) - Npeca75
- Workaround linksys always mapping to g1 (#13595) - glance-
- Equallogic fix typo on os name in the storage module (#13580) - iopsthecloud
Webui
- [WebUI] Removing the colon symbol to the right of a control label (#13698) - ilGino
- Remove unneccessary Section Description (#13677) - SourceDoctor
- Device tracepath using wrong variables to check for traceroute output (#13674) - laf
- Allow filter by display name in device list (#13665) - gdepeyrot
- Sort Vlan Ports by ifName, ifDescr (#13657) - SourceDoctor
- Fix horizontal scrollbar in device list always visible (#13653) - efelon
Alerting
Graphs
- Timos sap dot1q graphing fix (#13654) - loopodoopo
Applications
Api
- API detect if new location should be fixed by default (#13637) - murrant
- Set fixed_coordinates via api (#13593) - VirTechSystems
Polling
- Added oids.no_bulk os setting (#13666) - Npeca75
- Add consistent output of name and app_id to Poller for all Applications (fixes #13641) (#13648) - westerterp
- Fix SnmpQuery bulk boolean backwards (#13636) - murrant
Rancid
Bug
- Use PHP_BINARY directly instead of trying to build path to PHP binary (#13690) - Jellyfrog
- Small text change for misspelled Virtual (#13686) - ilGino
- Snmp timeout is a float, allow in config (#13676) - murrant
- Fix NULL device alert caused by services (#13663) - k0079898
- Disable VRP VLANs test, seems to be a bug in snmpsim snmpbulkwalk (#13649) - murrant
- Remove extra rows with duplicate keys in SyncsModels trait (#13632) - murrant
Documentation
- Update rrdcached link (#13692) - twelch24
- Add missing python3-pip installation dependency for debian11 (#13691) - tkjaer
