23.11.0
(2023-11-17)
A big thank you to the following 37 contributors this last month:
- murrant (26)
- PipoCanaja (5)
- jepke (3)
- peelman (3)
- dependabot (2)
- Galileo77 (2)
- tim427 (2)
- ottorei (2)
- eskyuu (1)
- arjenz (1)
- electrocret (1)
- GramThanos (1)
- bnerickson (1)
- peejaychilds (1)
- laf (1)
- luttermann (1)
- helppp (1)
- slalomsk8er (1)
- VirTechSystems (1)
- westerterp (1)
- cmadamsgit (1)
- lhwolfarth (1)
- webtroter (1)
- fbouynot (1)
- Wooboy (1)
- kmodzel (1)
- jaannnis (1)
- Fehler12 (1)
- not-known (1)
- drykov-ttc (1)
- tydal-borge (1)
- iNuc1ear (1)
- mpikzink (1)
- WilliamDEdwards (1)
- RandGH (1)
- underscoredje (1)
- Schouwenburg (1)
- murrant (40)
- Jellyfrog (10)
- electrocret (9)
- laf (2)
- ottorei (2)
- kwangsing3 (1)
Feature
- Mail Transport: option to use BCC (#15554) - murrant
- New command: lnms report:devices (#15539) - murrant
Breaking Change
Security
- Fix a few XSS vulnerabilities in device group popups (#15581) - murrant
- Disable GET login by default (#15558) - murrant
- Use GitHub for vulnerability reporting (#15555) - murrant
Device
- [APC sensor] Actual state of alarm contact beside config state (#15576) - jepke
- Vertiv PDU show power graph in mouesover and device overview (#15543) - Galileo77
- Cisco WLC: fetch LWAPP SSIDs for client counts (#15531) - murrant
- Add sysObjectIDs for other models of PSS shelves (#15525) - peelman
- Added values from SFP DDM values for awplus switches (#15522) - luttermann
- Add support for Nokia 1830 PSS Optical gear (#15516) - peelman
- Add Support for Samlex America PSR-1200-48 Inverters (#15515) - peelman
- TrueNAS no longer supports zpool space usage (#15490) - murrant
- Vertiv pdu mg02e4w1 (#15484) - Galileo77
- Add FortiGate Environment stats (#15464) - westerterp
- Add support for FiberStore “data center” switches (#15445) - cmadamsgit
- Adding basic support for Datacom DmOS devices. (#15436) - lhwolfarth
- Apc ap 7900b (#15392) - webtroter
- Add definition fujifilmprinter (#15381) - Wooboy
- Initial support for Moxa EDS-4000 Series switches (#15293) - kmodzel
- Cisco SB Switch Temp and Fanspeed fix (#15225) - Fehler12
- Add support eltex more devices (#15108) - drykov-ttc
- Add support for Security Radar (#15053) - tydal-borge
- Add disk sensors for Oceanstor (#15010) - iNuc1ear
- Fix Fortinet HA-status polling state translations (#14921) - ottorei
- Add Quantum Scalar I6000 Tape Library (#14915) - mpikzink
- Add liebert detailsv2 (#14746) - RandGH
- Zyxel AP wireless client discovery enhancement (#14704) - underscoredje
- Dantherm hostname (#14223) - Schouwenburg
- Add Panorama log collection write rate (#13864) - ottorei
Webui
- Device links formatting changes (#15580) - eskyuu
- Only set user roles if they are defined (#15577) - murrant
- Fix Down/Up time error if device is unpolled (#15545) - murrant
- Fix health temperature degree display (#15541) - murrant
- Fixed BGP Remote peer link and graph in Routing Overview, or just static text when not a device in LibreNMS (#15535) - tim427
- Added BGP Remote peer link and graph in Routing Overview (#15532) - tim427
- Respect web_mouseover setting in popup component (#15530) - murrant
- Prefetch devices in group to avoid cost of subquery (#15511) - slalomsk8er
Alerting
- Give reason for alert template fallback (#15583) - murrant
- Add option to disable the send of acknowledgement alerts. (#15208) - not-known
Applications
- [bugfix] Passing $device into data_update_helper functions instead of declaring it as global. (#15542) - bnerickson
Api
- API Oxidized http source optimization (#15560) - murrant
- Get poller group (#15493) - VirTechSystems
Discovery
Polling
- Prevent non-unicode characters in ifAlias (#15585) - murrant
- BGP-peers if no data, skip (#15548) - murrant
- UCD-MIB polling check isset (#15547) - murrant
- Fix Ciscowlc error when bsnApIfNoOfUsers is not present (#15529) - murrant
Authentication
- Add auth_ldap_cacertfile and auth_ldap_ignorecert options (#15526) - peejaychilds
Bug
- Bug - Fix API Content-Type Header handling (#15574) - PipoCanaja
- Huawei Controllers - Exception removed and changed OID for AP Type (#15564) - PipoCanaja
- Fix graphs device check before auth (#15551) - murrant
- Prometheus on failure, disable for rest of run (#15546) - murrant
- Bug - Fix missing device_id in NAC tab view (#15534) - PipoCanaja
- Bug - string VS array (#15533) - PipoCanaja
- OSPF tables fix integer types (#15528) - murrant
- Fixed the wrong field being used for join (#15524) - laf
- Dark mode fix routing tabs & pages (#15485) - jepke
- Minor fix and tweak for graylog integration (#15455) - jepke
- Smokeping menu and title use device displayname (#15387) - fbouynot
- Increase max package name length to 128 characters (#14895) - WilliamDEdwards
Cleanup
- Remove api_demo config setting (#15563) - electrocret
- Wifi module does not exist anymore (#15549) - murrant
- Misc device column cleanups (#15518) - murrant
Documentation
- Update Docker docs (#15556) - GramThanos
- Changed log item, source(s_sys) to source(s_src) (#15521) - helppp
Translation
Misc
Internal Features
Dependencies
- Bump axios from 0.25.0 to 1.6.0 (#15571) - dependabot
- Bump browserify-sign from 4.2.1 to 4.2.2 (#15510) - dependabot
