23.5.0
(2023-05-19)
A big thank you to the following 37 contributors this last month:
- murrant (29)
- Jellyfrog (6)
- mtentilucci (5)
- peelman (4)
- electrocret (4)
- laf (3)
- cjsoftuk (3)
- alchemyx (2)
- Bierchermuesli (2)
- bakerds (2)
- mpikzink (2)
- TheMysteriousX (2)
- QuadPiece (1)
- elipsion (1)
- etiennewan (1)
- jlo-lirmm (1)
- dscw (1)
- fbouynot (1)
- santiag0z (1)
- dependabot (1)
- VoipTelCH (1)
- otkd (1)
- ajsiersema (1)
- JStandiford (1)
- PipoCanaja (1)
- arjenz (1)
- maticomba (1)
- SourceDoctor (1)
- pjroehl (1)
- cjwbath (1)
- MajesticFalcon (1)
- bnerickson (1)
- bestlong (1)
- Olen (1)
- mboehn (1)
- ollb (1)
- eskyuu (1)
- murrant (47)
- electrocret (18)
- Jellyfrog (16)
- ottorei (1)
- PipoCanaja (1)
- JohnnyBBravo (1)
Feature
- Set focus to Global Search on Ctrl-F (#14947) - Bierchermuesli
- Add link to hosts mgmt (ipmi) interface (#14905) - mpikzink
- Implement authentication for Redis/Sentinel (#14805) - TheMysteriousX
Security
Device
- Add RoomAlert 12E Switch Sensors, fix Humidity Sensor (#15049) - peelman
- Fix WISI over graphs (#15040) - peelman
- Fix inventory display for Calix AXOS devices (#15039) - peelman
- Map GPS lat and lon to os module (#15033) - QuadPiece
- Firebrick CPU Monitoring (#15030) - cjsoftuk
- Fix Firebrick mempool polling (#15022) - cjsoftuk
- Add support for memory monitoring on Firebrick platform (#15021) - cjsoftuk
- Fix vsolution discovery yaml (#14970) - murrant
- Fix tait tnadmin processors (#14969) - murrant
- Fix Raisecom Processor (#14968) - murrant
- Fix Raisecom ROS processor collection (#14966) - murrant
- Add support for Trellix ATD devices (#14965) - mtentilucci
- Add support for Trellix NSP devices (#14964) - mtentilucci
- Cisco QFP polling fixes (#14961) - Bierchermuesli
- Add version, hardware and serial collection (#14956) - JStandiford
- Add Rubrik Discovery (#14951) - mtentilucci
- Add Nutanix AOS discovery (#14950) - mtentilucci
- RouterOS runtime quirk on first discovery (#14945) - murrant
- Added sensor support for older APC InfraStruXure PDUs (#14944) - bakerds
- Expand discovery of gigavue os (#14933) - mtentilucci
- Add discovery of NVT Phybridge FLEX24 (#14913) - pjroehl
- Add initial OS detection for LoadBalancer.org (#14902) - cjwbath
- Added graphing of DDoS-protection related OIDs for PAN-OS (#14847) - bakerds
- Add support for Alpha CXC HP Controller (#14829) - MajesticFalcon
- Change ESXi port naming to be stable (#14639) - TheMysteriousX
- Add advantech icr-os for advantech routers (#14171) - mboehn
- Fix cisco dbm sensors port link on discovery (NCS55A2) (#13965) - ollb
Webui
- Ondemand popup graphs (#15050) - murrant
- Add a global setting for Ctrl-F focus (improve #14947) (#15023) - etiennewan
- [About] Link to LinkedIn (#14991) - santiag0z
- Clarify Alert Notify Settings (#14974) - electrocret
- Fix Legacy vars Processing (#14967) - murrant
- Correct PowerConsumed SI Units in Overview (#14425) - mpikzink
- Added support for user timezones and user browser timezone by default (incomplete) (#13626) - eskyuu
Alerting
Graphs
- Php implode arg mismatch (#15014) - jlo-lirmm
- Fix availability graphs to 100% (#15013) - laf
- Fix scale_rigid accidentally being set to false (#14992) - murrant
- Set device ping_perf scale_min to 0 (#14989) - murrant
- Poller perf: add per device average (#14940) - murrant
- Stacked graphs on zoom to speed (#14928) - electrocret
Applications
- Adding linux_config_files application support (#14776) - bnerickson
- Agent support OS Updates (#14687) - bestlong
Api
- Allow device ignore to be set via API (#14985) - electrocret
- Enable disabling a device via api (#14983) - VoipTelCH
Discovery
- Snmp-scan filter for dns resolved devices (#14934) - SourceDoctor
Polling
- Fixes #14957 missing IPv6 BGP peers (#14959) - ajsiersema
- Fix SnmpQuery and max_oid (#14955) - murrant
Bug
- Fix timetaken columns too small (#15042) - murrant
- Fix some undefined constants (#14993) - murrant
- Fix routes after Laravel9 (#14977) - Jellyfrog
- Fix more divide by zero issues (#14954) - murrant
- Bug - wrong type in ports.inc.php (#14952) - PipoCanaja
- Solves error in discovering services module (#14939) - maticomba
- Ensure irc fifo-file is shared between dispatcher and core containers (#14647) - Olen
Refactor
- Add a validation for checking if the scheduler is running (#14987) - Jellyfrog
- Refactor billing (#14979) - murrant
Cleanup
- Remove old unused adduser page and script (#15035) - murrant
- Adopt anonymous migrations (#15005) - Jellyfrog
- Remove unused port fields (#14963) - murrant
- Cleanup enable bgp setting (#14931) - electrocret
Documentation
- Re-add the Ubuntu Image page and links (#15041) - laf
- Remove references to VM images (#15031) - murrant
- Updated WebUI config options in docs to support direct linking to installs (#15009) - laf
- Fix spelling error in Graylog section (#15002) - dscw
- Update OAuth-SAML.md to prevent http code 419 error (#15000) - fbouynot
- Update Smokeping.md with better nginx config instructions (#14999) - alchemyx
- Update Copyright year to 2023 in README.md (#14972) - otkd
- Update Install-LibreNMS.md (#14949) - alchemyx
Tests
- Reduce OS module test noise (#15046) - murrant
- Test PHP 8.2 and MariaDB 10.11 (#15007) - murrant
- Slightly better OS module test output (#15001) - murrant
- Fix a bug when creating test data; if a community contained the strin… (#14739) - peelman
Mibs
Dependencies
- Bump guzzlehttp/psr7 from 2.4.4 to 2.5.0 (#14986) - dependabot
- Laravel 9.x Shift (#14504) - Jellyfrog
