23.9.0
(2023-09-15)
A big thank you to the following 16 contributors this last month:
- murrant (33)
- SourceDoctor (3)
- VVelox (3)
- eskyuu (2)
- PipoCanaja (2)
- MrMoCoDev (1)
- electrocret (1)
- Pelt10 (1)
- LoveSkylark (1)
- slashdoom (1)
- jepke (1)
- hanserasmus (1)
- adamsweet (1)
- fbourqui (1)
- fbouynot (1)
- Fehler12 (1)
- murrant (10)
- Jellyfrog (9)
- electrocret (8)
- PipoCanaja (3)
- VVelox (1)
- cltnoc (1)
- ottorei (1)
Feature
- Additional contact options for email transports (#15266) - murrant
- Implement RBAC (only built in roles) (#15212) - murrant
Security
- Fix injection vulnerability in fdb search page (#15315) - murrant
- Fix injection vulnerability in ports pages (#15314) - murrant
- Fix another addcslashes incorrect escape in eventlog (#15313) - murrant
- Fix another injection in ipv4 search page (#15312) - murrant
- Fix injection in search pages ipv4, etc (#15311) - murrant
- Fix improperly escaped output in outages page (#15310) - murrant
Device
- Fix smartos-dcp-m.yaml (#15295) - electrocret
- Use mtxrGaugeTable instead of mtxrHealthGroup (#15289) - murrant
- Added support for Nutanix VM count, disk state, CPU usage and RAM usage (#15252) - eskyuu
- Initial support for f5os (#15241) - fbouynot
Webui
- Fix login page HTML (#15321) - murrant
- Fix device display name in top interfaces widget (#15319) - murrant
- Timezone, fix user set no timezone (#15296) - murrant
- Availability Map: Show ignored device up when up (#15283) - SourceDoctor
- Custom ssh,telnet port with oxidized (#15255) - jepke
- WebUI Services, generate more compact table (#15243) - fbourqui
- Added empty string check (#15235) - Fehler12
- Use full name for vendor_oui (#15234) - PipoCanaja
- Add global NAC page (#15228) - PipoCanaja
Alerting
- Fix error when mail-contact is missing (#15305) - murrant
- Hide token, keys and passwords in Transports (#15274) - LoveSkylark
Applications
- For the applications table set the defaults for app_instance and app_instance to ‘’ (#15278) - VVelox
- Application Soft Delete (#15270) - VVelox
Api
- Allow port search API to search ifAlias again (#15320) - murrant
- Fix API availability graph duration (#15250) - murrant
Settings
Polling
- Fix port ifAlias polling (#15279) - murrant
- Fix ifSpeed override not being applied (#15237) - murrant
Authentication
Bug
- FIX TP-Link JetStream 3.0.0 Build 20180511 Rel.36491(s) T1500-28PCT 3.0 (#15318) - MrMoCoDev
- Fix issue with rrdcached application and bad input (#15301) - murrant
- Fix .env quoting issue (#15298) - murrant
- Fix typo in default mibs for SnmpQuery (#15297) - murrant
- Readd missing key (#15291) - SourceDoctor
- Fix missing keys for new status (#15284) - SourceDoctor
- Revert “Added empty string check” (#15249) - murrant
- Fix manual port speed storage (#15238) - murrant
- Make the service template controller re-evaluate dynamic membership when apply all button is pushed (#15214) - eskyuu
Cleanup
Documentation
- Note the package install command for dhcpd-pools for FreeBSD (#15247) - VVelox
- Update severity colours in SNMP-Traps.md (#15244) - adamsweet
Misc
- Another OR statement in GrayLog API (#15246) - hanserasmus
- Dispatcher option to log output (#15230) - murrant
