as example the next one works APC Web/SNMP Management Card (MB:v3.9.2 PF:v3.7.3 PN:apc_hw02_aos_373.bin AF1:v3.7.2 AN1:apc_hw02_sumx_372.bin MN:AP9617 HR:A10 SN: ZA0636015734 MD:08/30/2006) (Embedded PowerNet SNMP Agent SW v2.2 compatible)
Is there a way to rewrite the code so that it checks the OIDS first and if it was successful it can go the way it is, if not it falls back to the old OIDs ?
@TheGracens
The current patch is now reverted. So you’ll get your sensor back next time daily.sh is run. And a new patch is in preparation to avoid this issue.
