AutoScale for Traffic graphs after 21.8 (24 July)
I noticed after last night’s update that the port bit graph now have a line across the graph representing the port speed:
This now effectively hides the traffic view in detail (since the scale automatically adjusts to display the port speed line). Is there a way of turning this off? or a different graph type or graph option to remove this new line?
librenms@piserver:~$ ./validate.php
LibreNMS 21.8.0-9-g8e409ba05
DB Schema 2021_25_01_0129_isis_adjacencies_nullable (216)
PHP 7.4.22
Python 3.7.3
MySQL 10.3.29-MariaDB-0+deb10u1
RRDTool 1.7.1
SNMP NET-SNMP 5.7.3
[OK] Composer Version: 2.1.5
[WARN] Global lnms shortcut not installed. lnms command must be run with full path
sudo ln -s /opt/librenms/lnms /usr/bin/lnms
[WARN] Bash completion not installed. lnms command tab completion unavailable.
sudo cp /opt/librenms/misc/lnms-completion.bash /etc/bash_completion.d/
I second that.
Hello
You can disable this behaviour in the preferences. (Graphs, scale based on traffic OR link speed)
Thank you! For those of you who need to change it, go to Global Settings → Web UI → Graph Settings → Zoom port graphs to port speed (turn off)
