I am trying to optimise the sorting of devices on the overview page (https://<base_url>/devices). As of now devices registered by their IP-Adress are sorted by the leading digit of each segment. I would like to do the following.
Now: Fixed:
192.168.1.1 192.168.1.1
192.168.1.100 192.168.1.2
192.168.1.2 192.168.1.100
192.168.1.200 192.168.1.200
My problem is, that I can not find the matching template files within the repository. Can someone point me in the right direction?
My research shows, that PHP has a ip2long() function that could be of use.
Thank you for your help!
Lucas
includes/html/pages/devices.inc.php - I found that with grep -R 'Up/Down Time' . as a unique element.
I tried the debugbar, but across it all I can’t find any reference to that and see it’s using the LegacyController - so guessing it hasn’t been converted over to laravel blades and not going to be able to dig much via that. I know very little about that world though.
That seems to be the right page. I’ll try to wrap my head around the table generation. TBH I expected the sorting to be handled by JS, but it seems to be done by php on loading…
Okay, the table content is returned by an Ajax request to https://<base_url>/ajax/table/device. I was not able to locate the corresponding script just yet.
I’m no wiser on it really, but have a look at:
app/Http/Controllers/Table/DeviceController.php
app/Http/Controllers/Ajax/DeviceSearchController.php
They smell relevant to me, but I don’t know how they are called and what magic is going on to leverage them.
I notice this also, but I’d also love to be able to sort by DisplayName vs. hostname for cases where DNS is not used.
I’m trying to go through the files, but found nothing yet. Did anyone figure it out yet?
