I have a customoid that polls correctly (I can see from “Capture” → “Poller” run for device and can see from snmpwalk output). The OID outputs an integer. At every 5 min poll, the OID value will be a whole number, like 2, 3, 5, etc. It can also be zero. Again, the poller shows the same value as my snmpwalk. However, the graph does not graph an integer value. If the poll for that 5 min poll cycle was 4, the graph may graph 3.8, or 4.1 for that poll interval. My graph is using “Guage” and divisor and multiplier are both 1.
Here was another post about the same issue, but had no replies.
