I have a problem with one value in a graph on 3 devices (Windows Servers).
I read CustomOID from the server, the result value in the CustomOID tab is correct (it is an integer, e.g. 1, 3, 15, 40).
I don’t understand why how to graph for this CustomOID item it takes the unit M or u or shows completely different values.
The same function to the other server works fine and grapf shows the correct integer units.
Correct grapf (unit and value)
Incorrect grapf (unit and value)
- The output of
./validate.php
