GitHub issues is for bugs, please do not post issues asking for help or how to do X, Y or Z.
You can use our irc channel ##librenms on freenode to ask questions or our community site.
If you have a feature request please post this on our community site.
Please confirm each of the sections below by putting an x in the box like [x].
Is your install up to date? Updating your install
Please do not submit an issue if your install is not up to date within the last 24 hours or on a stable monthly release.
Please include all of the information between the ==================================== section of ./validate.php which you can run from the cli.
Please do NOT post more than 10 lines of debug information here, use a pastebin service or GitHub Gists.
Could You add to LibreNMS possibility to discover and read some values from GPON ONTs.
Below quick description how it is done on DASAN Zhone GPON devices (examples with NET-SNMP):
As it is in the file - we cannot read values directly from ONT. We need to read it from OLT - which via control channel will read it from ONT - but I think in that way it is easiest to implement.
All SNMP data You can find in sle-gpon-mib.mib but there are a lot of information so could You at first implement few of them:
Status
Serial Number
Distance
Rx Power
Profile
At first there need to be possibility to discovery all connected ONTs and add them to the correct port.
I am not sure how will it be better to do - some suggestions:
a) add new TAB to main devices view - GPON ONTs (where we have for example Map/Inventory/Services/etc.)
b) add new TAB when we sellect GPON port for example PORT1-GPON (where we have Graphs/Real time/ARP Table/etc.)
c) somewhere else
No matter which one could be use I think better will be not to read all information from OLT (ONTs) when we click tab GPON but something like that:
Select main tab “GPON ONT” → Select correct “GPON PORT” → then there could be list of ONT with only brief information like (ONU-ID/Status/GPON SN/Distance/RX Powe/PROFILE/Description) → then after select correct ONT there will be more additional information (in future)
Below example how it could look like:
Please let me know if You need additional info.
I can also provide You remote access to one of the OLTs if You would like to test - please send me private message.
