How can the dashboard librenms length limit length limit be modified?
Because I asked if I lengthen the widget, I can only put down 9. If the length is shorter, I can put 15
Over the length will be covered and cannot be displayed
thank
Hello ![]()
There is no way currently, see more info here 15 Widget - Dashboard Limit? - #9 by Chas
Hello, I have seen that article is a quantitative limit.
What I am currently experiencing is the length limit.
Only 9 can be used
