We’ve ran into an issue twice where we end up with around 400+ rrdtool defunct processes. We had then seen a few weird issues, such as reporting some BGP errors when there were none.
| Component |
Version |
| LibreNMS |
1.30 |
| DB Schema |
200 |
| PHP |
7.0.16 |
| MySQL |
5.5.52-MariaDB |
| RRDTool |
1.6.0 |
| SNMP |
NET-SNMP 5.7.2 |
So we were wondering if this was a known issue? I hadn’t seen anything in the forums about it and so far we had rebooted the server to “fix” it, but next time we might start with restarting php-fpm first.
It is running on CentOS 7.3.1611, kernel 3.10 and Nginx 1.10.2-1.
Thanks again
are you running memcached?
No we aren’t and it’s not even installed on the system
What version is $config['rrdtool_version'] set to?
In config.php? It isn’t defined
I wanted to unfortunately revive this topic to see if anyone else had a clue, as we’ve had it happen again and ended up restarting the system since it was starting to cause false alarms. Only difference is that we are now at these versions:
Version 1.32 - Sun Oct 01 2017 14:58:39 GMT-0400
DB Schema #209
Web Server nginx/1.10.2
PHP 7.0.22
MySQL 5.5.52-MariaDB
RRDtool 1.6.0
Thanks again
in your config.php did you specify the version for rrd
$config['rrdtool_version'] = '1.6.0';
No, it wasn’t, but we hadn’t set up rrdcached either, and I thought it was only required for that part of the installation. I guess this means it’s good practice to configure this statement all the time?
It only makes a difference if you are using rrdcached, which frankly everyone should be using.
