Distributed poller set up
Is there a complete tutorial on distributed poller setup?
I followed the installation document http://docs.librenms.org/Installation/Installation-Ubuntu-1604-Nginx/ to setup the DB, web front, but would like to have one poller on each datacenter. How do I do that?
Any helps will be appreciated.
Yep: http://docs.librenms.org/Extensions/Distributed-Poller/
Many Thanks @murrant
I am very new to this.
Is a poller generally means a librenms installation?
where should I install rrdcached and memcached? Can they both be installed on the web front end or the database server?
Yes a poller is a normal install but you don’t need to run mysql, memcached and rrdcached locally. These should all be installed in one central place - where - is up to you.
Is my diagram of how i’m setting up my distributed LibreNMS setup, if that helps you visualize anything
Thanks All!
These are very helpful to me!
I was having some issues after I installed memcached and rrdcached. The graphs stopped drawing, the poller still polls, but nothings shows on the graph after I bounced nginx.
I put web front, rrdcached, memcached and a poller on one box.
I follow this doc to install and configure memcached http://docs.librenms.org/Extensions/Memcached/
this doc to install and configure rrdcache for ubuntu http://docs.librenms.org/Extensions/RRDCached/
Finally, I follow the document @murrant gave me to configure everything again.
Then after all of that, the graphing stopped working. When I validate my installation, I got this:
[FAIL] Cannot connect to rrdcached instance
Any clues?
Harry
Run ./validate.php first of all.
Likely it is a file permission issue.
That is the output of the Validate.php
I put this configuration in the config.php file in /opt/librenms
Can someone kindly help me to verify?
# Memcached
$config['memcached']['enable'] = true;
$config['memcached']['host'] = "localhost";
$config['memcached']['port'] = 11211;
# RRDCACHED
$config['rrdcached'] = "unix:/var/run/rrdcached.sock";
#$config['distributed_poller'] = true;
#$config['rrdcached'] = "localhost:42217";
$config['distributed_poller_name'] = file_get_contents('/etc/hostname');
$config['distributed_poller_group'] = '0';
$config['distributed_poller_memcached_host'] = "localhost";
$config['distributed_poller_memcached_port'] = 11211;
$config['distributed_poller_host'] = "localhost";
$config['distributed_poller_port'] = 11211;
$config['update'] = 0;
Remove the above.
You’ve already posted the issue, we can’t connect to rrdcached so check it’s actually running on 42217 (netstat -anp|grep 42217).
Thanks @laf !
After commented out the section you mentioned above, I was still having issues. When I grep port 42217, its not there.
So I took out the line $config[ā€˜rrdcached’] = 42217 , now the config looks like below and it works, at least no error on validation. But I wondering how will it work for other pollers if rrdcached port not open?
$config[ā€˜distributed_poller’] = true;
$config[ā€˜rrdcached’] = ā€œunix:/var/run/rrdcached.sockā€;
$config[ā€˜distributed_poller_name’] = file_get_contents(’/etc/hostname’);
$config[ā€˜distributed_poller_group’] = ā€˜0’;
$config[ā€˜distributed_poller_memcached_host’] = ā€œlocalhostā€;
$config[ā€˜distributed_poller_memcached_port’] = 11211;
$config[ā€˜distributed_poller_host’] = ā€œlocalhostā€;
$config[ā€˜distributed_poller_port’] = 11211;
$config[ā€˜update’] = 0;
It won’t but basically you’ve not configured rrdcached to start on port 42217 so you need to fix that first.
Got it! I uncommented NETWORK_OPTIONS="-L" and commented out SOCKFILE=/var/run/rrdcached.sock
in the config.php, I changed this line from $config[ā€˜rrdcached’] = ā€œunix:/var/run/rrdcached.sockā€; to $config[ā€˜rrdcached’] = ā€œ127.0.0.1:42217ā€;
Bounce rrdcached and it is now listening to port 42217.
Validated setup and no errors.
I assume that means its working?
Many Thanks for the help!
Continue to setup first poller.
Fingers crossed it does mean it’s working :slight_smile:
It worked indeed!
So I spun up another poller and move the devices to that poller, it seems all the servers devices worked with that poller but not the networking devices. When I moved it back to the default pooler after a while, they all appear to be offline. I tried delete a device and re-add it, but wasn’t success, webserver timed out.
Any Clues?
Most likely you aren’t allowing icmp / snmp from the new pollers IP.
yeah, I think that’s most likely the case.
When I move them back to the default poller and they still not working. The default poller IP should be allowed on those devices. They were working before I moved them to the new poller and back.
Is there a way to delete a device and clean all the memcached and db history about that device and treat it as new?
Harry
Data like that isn’t stored in memcache. Removing a device should clear all it’s data out.
If you run ./poller.php -h HOSTNAME -d -m os -r -f it will give you some debug on what’s wrong.
I am very confused on setting up the poller.
My current config for a poller.(see below)
172.16.37.209 is where the master poller/memcached/rrdcached located and they use 11211 and 42217 make sense because this host need to get to those services via these ports.
The lines that threw me off was $config['distributed_poller_host'] and $config['distributed_poller_port'].
I put this poller’s IP on this line and put 11211 in the port section, but I felt its not right. What is port 11211 is used for in this case? Does this connect back to the memcached server?
If I put 172.16.37.209 there, then it still not making sense since its asking for the distributed_poller_host.
Any helps will be very much appreciated!
$config['distributed_poller_group'] = '1';
$config['distributed_poller_memcached_host'] = "172.16.37.209";
$config['distributed_poller_host'] = "172.30.16.102";
$config['rrdcached'] = "172.16.37.209:42217";
Those are wrong. Ignore that the docs need updated. Just remove those two lines.
Thanks all!
Finally got my distributed pollers setup.
All thanks to you guys!
Cheers
